Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
The steel shaft is the key. The stock aluminum shaft will always wear.turbo flash does exactly same as i have done several times... with exception of the grease nipple, ... the spray graphit on the cross country steel shaft wrks great.... like i said just polish the shaft and put o ring either side and do a washer between the shortened spacer pipes.and o ring
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I ordered some different bushings and different material.
In the end, I am going to try this set up. It gives me an extra 1/4 inch of bushing material on the shaft.
I cut the bushing to size, added a bit of grease in the center and the fit was perfect. We will see how it holds up.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
What type of material did you source for the bushing and where did you source it from? It looks like a good fit.I ordered some different bushings and different material.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Bronzebushings.com
I used a oil impregnated brass bushing
I had to trim them a bit.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
Thank you for the info. Much appreciatedBronzebushings.com
