hondo
Hi Jeff,
If you look at the schematic it looks like the part #43 (line) points to the weld seam. On this side of the schematic below the holes, the black line would also indicate the weld seam.
I see what you are saying Maddogjeff. I wish my camera had fresh batteries to take a picture of the separated pivot arm bracket the day I was at the dealership. I guess it is the bottom or front depending how you look at it.
It looks like aventure cut the holed flange out, made his own support bracket and bolted it in. Looks like a solid fix. Towings design looks good too.
Point is, we want to prevent the black spring blocks from separating from the pivot arm, and releasing the springs. When that happens everything goes flat. There is a "ton" of pressure on those spring blocks.
I also can see where at higher speeds the spring ends could gouge the track, or worse.
I think the the issue now is how can we ensure everyone can get an upgrade from Yamaha via a safety recall.
Maddogjeff, do you still have your skid out, and can you see any fatigue?
