RTX 120mph personal best *videos*
..Machzed.. no Yamy clutch goes to the top unless you shave the faces to make room...then you have to cut the heel of the helix to allow for more spread on the secondary..if you've got the power to finish the helix that is..lol....and as far as the reverse/non-reverse thing goes...if the new caliper wasn't wider at the bolt centers you could gut the rev-gears out and use a RX outer case...dimensions (other than brake) are the same..also it's made of Mag (Apex) not aluminum
