RTx99
anybody having real bad slider wear on 2007 rtx i have 350 miles and i think i need new ones or a wheel kit at the back there suppose to be an up date kit not sure will let everyone know
Mikecam
I have 850 miles on mine and I've ordered a set of yellow ones already. Athough it has really improved since i loosened the track off. I left it tight because everybody said it would stretch some but I don't think it has. Took one and a 1/4 turns out of the adj's . Mine are within 1/16 of the wear line but have stayed there for the last 200 miles. Everybody else seems to have wear at the front of the sliders but my wear is right in front of the rear idler wheels. Hoping for some more distance out of the next set.
ReX
I haven't had a chance to run mine yet (no snow), but I picked up the "accessory" pair of idler wheels and mounts for it.
If you check the on-line fiche there is an extra pair of idlers shown in the 07 RTX suspension that the sleds were not shipped with. It's this extra pair that I am installing on mine.
maddogjeff
- Mar 27, 2005
- Ride northern Vt & QC, live in Ct
Don't know if they changed the '07 Ripsaw track but this has been an issue for the last 2 years.
Hyfaxes, hifaxes, slides, sliders, runners, whatever you want to call them, there seems to be a major issue with wear on any sled with the Ripsaw track that is clipped only every 3rd rib and has the closed window every other window. In other words you have a clipped rib, open window, non-clipped rib, closed window, non-clipped rib, open window. Supposedly the closed window was to catch snow but all it did was rub against the slide, heat it up and build up plastic on the closed window.
There seems to be 5 solutions that have been posted.
1. Put on low snow wheels and add additional idler wheels. This can be expensive and if Yamaha made a decent idler wheel (whole other issue), this could be a long term fix.
2. Cut out the closed windows and clip all the ribs. This is very time consuming and prone to mistakes and somewhat expensive but it works and is a long term fix.
3. SLP anti-wear pads. Cheap, $30. Easy, 2 hours of labor. They work. I put them on my '05 Rs Venture at the beginning of this year and have put on 1700 miles and have only worn off 1.5mm of hifax. The Venture atarts with 18.5mm of hifax and has a wear limit of 10.5mm giving me 8mm of usable hifax. Last year after 1700 miles I had worn off 6mm. Based on this year's rate of wear with the pads, my hifax should last 9,000 miles - SWEEET. One problem with these is that the pads themselves wear, don’t know how long they’ll last but for the price and time to do it, won’t mind replacing them once in a while.
4. Change out the Yamaha idler wheels and put on oversized Poo/Doo wheels. You have to machine the mounts because of different sized bearings but this works and is a long term fix.
5. Be patient, let them wear all the way down. Get a pair of calipers and measure the actual wear. The Venture hyfaxes start off with 18.5mm (top to bottom), manual says wear limit is 10.5mm, giving you 8mm of wear. The first 4mm melted off in 450 miles. At this point you get really nervous and want to change them out but then a switch gets turned on and they quit melting. MM 5 lasted for 450 miles. MM 6 lasted for 500 miles. MM 7 lasted for 830 miles and still half of it to go. I put on 3000 miles ‘04/05 season. And that was the end of the season. I would have loved to seen what that last 1.5mm would have lasted but I'm putting a new set on for the next season. Most people think that the slides just get conditioned, I believe they just become thin enough so that the rails start acting as heat sinks and dissipate enough heat to keep them from melting. That last 1.5mm just may have lasted this whole next season. Having said all this I still hate being nervous about them and decided to use the anti-wear pads.
Boys, don't hold your breath, get some piece of mind and go with solution 3.
Starting Line Products 208-529-0244
http://www.startinglineproducts.com/
Part # 25-102 Anti-Wear Pad Kit 40 Pak (other packs available)
Part# 20-160 Track drill 1/4"
Pics -
Look at this thread -
Pics -
