JustABlurRx1
- Feb 26, 2007
Hi All,
I have an 03 RX-1 with some ignition switch issues. I suspect there is a short in the wires, since I have intermittent issues starting the sled. I can move the wires around coming out of the harness and into the ignition switch and get it to start for a while, but then it will inevitable fail to start again eventually. I replace the ignition switch itself to eliminate that. Rather than buying a whole new wiring harness.. does anyone know if/how I can rewire the ignition wires without replacing the entire harness?
Thanks in advance!
Markus
Thanks in advance!
Markus
