Forgot to add that im using a wrp seat.
Phazed Out
- Mar 19, 2020
- MN
- 1984 John Deere Sprintfire 340 L/C
1984 Phazer 480
1988 Phazer 480
2000 Phazer 500
2004 RX Warrior
2005 RS RAGE
2005 RX-1 ER Limited Edition
2007 Apex ER
I thought about that, I may do it on my ‘05. How hard are those to install?Forgot to add that im using a wrp seat.
It wasnt too bad. I used an air stapler to install their foam and cover on my stock seat pan. Its like riding a different machine. Foam is pretty dense and gives good supportI thought about that, I may do it on my ‘05. How hard are those to install?
Phazed Out
- Mar 19, 2020
- MN
1984 Phazer 480
1988 Phazer 480
2000 Phazer 500
2004 RX Warrior
2005 RS RAGE
2007 Apex ER
It wasnt too bad. I used an air stapler to install their foam and cover on my stock seat pan. Its like riding a different machine. Foam is pretty dense and gives good support[
Does the powerRiser seem like enough rise with that seat?
Phazed Out
- Mar 19, 2020
- MN
1984 Phazer 480
1988 Phazer 480
2000 Phazer 500
2004 RX Warrior
2005 RS RAGE
2007 Apex ER
Does the PowerRiser seem like enough height with that seat?
I think its just right. I am 5’11” seat puts your knees well below your hips. Got little over 5k miles on the seat/riser combo so far
Phazed Out
- Mar 19, 2020
- MN
1984 Phazer 480
1988 Phazer 480
2000 Phazer 500
2004 RX Warrior
2005 RS RAGE
2007 Apex ER
Good to know, I’m 5’10” and was a bit uncomfortable on the Warrior last season. The Rx-1 was fine with the higher seating but definitely needed hooks and risers. Cant wait til I get this stuff so I can put it on.I think its just right. I am 5’11” seat puts your knees well below your hips. Got little over 5k miles on the seat/riser combo so far
Fortress
- Dec 18, 2016
- West Canada
- 2004 RX1
You definitely want a pivot riser! I made mistakes of just using the 2” block riser and it makes the bars come closer to you cause the stearin stem is wrong angle on the rx1.think they fixed angle on the 2006 apex?
Fortress
- Dec 18, 2016
- West Canada
- 2004 RX1
Oh and I got the 90 degrees hooks like above pic but they say Polaris on them
Phazed Out
- Mar 19, 2020
- MN
1984 Phazer 480
1988 Phazer 480
2000 Phazer 500
2004 RX Warrior
2005 RS RAGE
2007 Apex ER
That’s why I got the powerRiser. I was looking at my sleds, and like you said, with a plate(flat) style riser, the bars come closer to you.You definitely want a pivot riser! I made mistakes of just using the 2” block riser and it makes the bars come closer to you cause the stearin stem is wrong angle on the rx1.think they fixed angle on the 2006 apex?
Did you drill out the end river on your handlebars to make the hooks fit? I just hope I don’t ruin the hand warmer element.
Fortress
- Dec 18, 2016
- West Canada
- 2004 RX1
The hooks are for 7/8 steel bars so they fit right in just cut a hole for them at end , the heated part is only in middle of grips.I have aluminum bars on now though that I had to transfer everything over to, it was pretty easy but I had to drill out the aluminum ends to get them in and shave the hooks down,it sucked but worth it for new bars.
Phazed Out
- Mar 19, 2020
- MN
1984 Phazer 480
1988 Phazer 480
2000 Phazer 500
2004 RX Warrior
2005 RS RAGE
2007 Apex ER
Okay, because I think all Stock bars for RX’s have the aluminum rivet at the end to keep the grips on and from spinning. I need to cut the end rubber away, and grind or drill out that end rivet, and probably shave down the end rubber flare. I’ll probably wrap ‘er all up in hockey stick tape when I’m doneThe hooks are for 7/8 steel bars so they fit right in just cut a hole for them at end , the heated part is only in middle of grips.I have aluminum bars on now though that I had to transfer everything over to, it was pretty easy but I had to drill out the aluminum ends to get them in and shave the hooks down,it sucked but worth it for new bars.
Fortress
- Dec 18, 2016
- West Canada
- 2004 RX1
That’s right you can pencil grind the rivet almost off leave a bit and rivet will still work,I basically got a really sharp knife and cut a hole keeps the grip stronger then just cutting the end off
Phazed Out
- Mar 19, 2020
- MN
1984 Phazer 480
1988 Phazer 480
2000 Phazer 500
2004 RX Warrior
2005 RS RAGE
2007 Apex ER
Yep, that’s what I think I will do.That’s right you can pencil grind the rivet almost off leave a bit and rivet will still work,I basically got a really sharp knife and cut a hole keeps the grip stronger then just cutting the end off
By the way, how did you retrofit your apex seat wire to your rx? Did you swap the whole seat harness, or just splice on new connectors, or something else?
Fortress
- Dec 18, 2016
- West Canada
- 2004 RX1
I’m pretty sure it plugged right in ,but yeah if not ,it’s just 2 wires to splice/connect
- 10K
