Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
Below are some simple step-by-step procedures to easily replace worn ski bolt bushings (where the ski attaches to the spindle) on the RX / RS sleds. It just so happens that an outer, lower A-arm collar (in the aluminum spindle housing) is the perfect size to drive out the old bushings, without dinging up the bore with a punch or chisel. I used an old collar and bolt from an RX1.
I would recommend cleaning old grease and grit out the spindle bore before removing the old bushings, or the collar could wedge in the bore.
Enjoy!
Enjoy!
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
nice thanks for the write up.
Dusty Dan
- Jan 24, 2015
- 2016 SRViper LTX LE
2012 Vector
Excellent work, as usual.Below are some simple step-by-step procedures to easily replace worn ski spindle bushings (where the ski attaches) on the RX / RS sleds. It just so happens that an outer, lower A-arm collar (in the aluminum spindle housing) is the perfect size to drive out old ski spindle bushings. I wouldn't use a good A-arm collar to do this, but a used one will work fine.
I think this job could be carefully performed with the spindle still on the sled, just don't beat them too hard. All-thread, nuts and washers could probably be used to squeeze new bushings in as well. It's a simple job, just take your time!
Enjoy!
View attachment 118777 View attachment 118778 View attachment 118779 View attachment 118780 View attachment 118781 View attachment 118782
- 46K
- 11K
