RB Racing
- May 15, 2016
- Winnipeg
- 2013 Nytro xtx 1.75
- Winnipeg, Canada
Are these kits still available?
Pries
- Dec 6, 2015
- Calgary
- 2007 RS Venture
2008 Nytro MTX
Me too please...are the kits available for a 2008 Nytro MTX?
TMBVLMP13
- Dec 18, 2017
- Bethel AK
- 2013 VLMP
I'd like to order a spindle bushing kit as well please. 2012 venture MP
YukonMP
- Dec 25, 2014
- Yukon Territory
2014 Venture MP here, please contact if kits are available.
TMBVLMP13
- Dec 18, 2017
- Bethel AK
- 2013 VLMP
Anyone know if these are still available?? if so where from.??
XXFETTXX
- Sep 14, 2013
Email sent about Nytro kit
SnowBandit
- Jan 31, 2004
- NH
- www.slednewengland.com
- 2009 Nytro xtx
Anyone know if these are available anymore tried to email but it was bounced
They are still available, just bought 2 kits. 135.00 plus shipping.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
uptime@gmx.us is his Email. If you click the link on the first page it hotlinks to his old email for some reason.
UP bushman
It's been a while just a shout out to all the great comments on the product from you guys thanks again Rob.
Ron W
- Dec 31, 2021
- North Bay
- 2007 phazer
Hey there riders of the Phazer & Nytro Chassis with the aluminum spindles check for it starting to oval out were the ski mounts. The reason this has happened is the rubber ski stopper wears under the spindle causing the cheap split bushings to expand and wable out the spindle (Steering Knuckle Assy. Right & Left sides $194.55 each). My Phazer Mountain has 4831 miles on it and it's ovaled out to the eye. The pictures are as good as I could get with the pixel my camera has but you can get the idea.
If you also notice the gaps between spindle, spacers and ski it measured up to be 1/16" on mine lots of room to wable around. Without the rubber between the ski and spindle removed you will really notice the movement side to side for an example. The split bushing in the spindle will continue to oval out the spindle for there is no solid Bushing around the collar shaft to stop it. The Kit available below will save your Spindles.
To replace the stock parts in hopes of curing this problem it will not. Part cost 2-Collars (shafts) 90387-1012H $6.65.each, 2-Collars (spacers) 90387-16017 $3.93 each, 2-Collars (spacers) 90387-16018 $3.93 each, 4-Washers 90201-16022 $3.92 each, 4-Bushings, Bimetal Formed $5.50 each and you will spend approximately $66.70 total. A few guys have tried including myself and found out the hard way it does not fix it.
Premium Spindle Saver Bushing Kit $135.00 for all Phazer, Nytro trail and Venture Lite, $137.00 Phazer, Nytro Mountain + shipping $12.00 US, $22.00 Canada, $25.00 International made of stainless steel will come complete with all new bushings (double the wall thickness of the stock ones), spacers, collar, washers just reuse bolt and nut for the ski to mount to Spindle. This Kit is designed for stock ski mount setup if you have aftermarket ski's and use stock hardware it will work. Aftermarket skis that the Premium Kit fits C&A Pros Skis, Slydog Mountain Skis and more to be added as info comes in.
For purchase of Kits you can contact me via PM or email uptime@gmx.us thanks.
Ron W
- Dec 31, 2021
- North Bay
- 2007 phazer
How do I get the collars off to get at the bushings?
heatmiser2003
- Sep 19, 2022
- CT
- Yamaha Nytro
Hey UP, I sent you an email today, I am trying to get a set for an 09 Nytro. Thanks
Blizzard24
- May 9, 2022
- Wallkill, NY
- 2009 Apex ER
2007 RS Venture GT
2008 Phazer RTX
I also sent an email UP, looking for the steering kit and the spindle kit.
heatmiser2003
- Sep 19, 2022
- CT
- Yamaha Nytro
I have not heard back from him if I do I will let you know, can you do the same for me?I also sent an email UP, looking for the steering kit and the spindle kit.
