yamatyb9
this is probably a bonehead question but im overlooking something so any help is appreciated... hooking up a battery tender the charge it, the tender is not plugged in but even when i toouch the negative to connect it im getting sparks?? im just wondering why and im obviously over thinking this. any info is greatly appreciated. thanks
BigDogrx1
- Dec 2, 2014
- SOO (UP) MI
- 2003 rx1
switch hook up to correct colors
yamatyb9
yes i have them on the correct colors.. i made sure that wasnt the case! lol
forgot to mention the only reason im doing this is because i turned the key and get nothing so assumed it was dead which bugs me now cause theres obviously some juice left in it?? maybe im wrong
try a different charger if you have one. blew up the diodes in one at work and it was doing the same thing.
yamatyb9
The tender was brand new out of the box but I'll give that a shot! Thanks
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
If you still get nothing when you turn the key, check the ignition fuse in the little box on the right side of the steering gate.
yamatyb9
all my fuses are good, battery is full, still nothing when i turn the key still.. driving me nuts. unplugged the ignition and plugged back in, not sure what else to look at?? please help
Starter selonoid along side the battery. They fail. I believe you can jump the terminals with a screw driver to check it. 100$ from dealer. When mine went road the weekend tried to start it before next ride nothing.
if the solenoid is good then i suspect you have a bad ignition switch. i had one that stumped us for most of the winter on my 05 war until we found it.
yamatyb9
come to find out it really helps if the kill switch isnt on!! unbelievable , knew i was overlooking something easy! but im glad it was simple! embarrassed to say it lol but thanks for all the help!!
Not a problem. Glad that was all it was.
- 8K
