MtN_Rx1er
Hi i have a stock 04 rx1 mtn with 2k km on it and i had it in for the carbs cleaned/set/synced/old fuel drained and got it back today and started it, it fired up no problem but would not idle at all without the choke half on, even warmed up for the first 10 min if you took off the choke it would die,once warmed up after 10 minutes it would idle between 3000-4000 and wouldnt come down with backfire and if i turned the idle down a shade it would just drop instantly to 1000 and die if you gave it any throttle,but if turned just a hair it would go back to reving,after 20 min of tryin to figure it out i took it for a lil drive and bliped the throttle and it just sits and revs and backfires.
any help or advice to pin point this would be helpful, or something i may be over looking.. thanks!
