Don Buzinsky
i have to check it again cold before i am sure.
Don Buzinsky
added water to the battery and charged it a bit. seems to start every time now. i don't know if it was that or lack of use from the previous owner and now that i'm starting it the solenoid works better.
Len Todd
You may want to consider Load Testing the battery. You do not want to be dumped out in the woods.
Don Buzinsky
i don't believe an intermittent no start would be a battery, they are either there or they are not. it is probably a connection problem that has cleared.(i took the battery out to change the oil, so the connections are solid now)
