viperking
- Feb 7, 2006
- Boscobel Wi
- 2015 Yamaha Viper XTX LE
I just bought an rx1 and im wondering where the oil dipstick is so i can check the oil, can someone please help, thanks
4strokelover87
It's in the top of the oil tank on the chaincase side of the motor. You will need to unplug the wires running to it and then it just screws out.
grader
now that you know where it is, you need to know how to check it. run sled up to operating temperature and shut off. on level ground, remove sensor plug and remove dipstick. wipe clean and reinsert dipstick into tank untill threads touch tank, remove and read oil level. DO NOT THREAD DIPSTICK INTO TANK TO CHECK OIL LEVEL. when done thread in dipstick and connect sensor.
Honk
maybe its time to get a manual. There are many things you should know!
