Rx1 thumbwarmer help
Joe Dugdale
Ontario
Canada
2005 Yamaha rx1
Hey fellas, got an issue with my rx1 thumbwarmer... Seems like it goes to full power, or high and cannot be adjusted...so hot, it can barely be used... When trying to adjust on handlebar control, I don't even get a readout on the display... Did some reading, and thought it was cdi related... Swapped out with another.. Same thing.... Removedswitch, and with the tester, thereappears to be continuity whenadjusted... Tested wires from cdiback.... Appears to be none broken as I was able to complete a circuitwith tester.... Help please???
have 13.8 volts to both wires at thumbwarmer switch plug when idling, switch works as it should when I plug it into handwarmer, it controls them fine......
