SC oil Temp sensor?
Maddog
NH
I'll try again, I seem to have an issue with my oil temp sensor or the conection on my sc warrior. Not sure if something is missing in the connector or if sometning is broken. I would like a couple of pics of this connection if possible. Looking for a pic of it connected and a pic of it apart. This would be really helpful as I bought the kit used and I'm not sue if I did something wrong. Thanks
It will depend on how old the kit is. But if it is newer, there was a wiring harness that came with the kit so that the temp sensor was connected into the oil level harness. The temp sensor plugged into the new harness, the original oil level connector plugged into the new harness and the new harness plugged into the oil tank.
Hope this helps. I can take a picture of the new harness if needed.
Like pwdrnut said; with the newer kits there was a new harness that plugs directly into the oil level sensor on the oil tank and is wired to the idiot light system along with having a connector for the OEM oil level plug. If you have an aftermarket gauge like I do, the temp sensor screws into the bottom of the SC oil tank in place of the drain plug. Let me know which one you need pictures of and I can get them tommorow.
Jim
