hearnoevil
I find my sled almost impossible to turn out of a climb, so 90% of the time I go big or stick on the side of a hill.
Today I screwed up, there was hard snow under the snow and i hit it. When I went to try and turn out it was to late the track spun under me, I kept the sled to bar and went backwards faster then I went up. Was able to keep it straight and didn't loose it. I was lucky.
But anyway I'm gonna have to improve my turn out, I always feel the sled is gonna tip over unless I put 2 legs on one side of the board. How can I fix this, go wider, no sway bar?
This dam mavrick track gotta go, it should of gave me some traction.
Mtnviper
Vendor
hearnoevil
Removing the sway bar helps alot.
Not sure what your ski stance is, but I would keep it narrow. The idea is you want to be able to lay the sled in to the hill side and have it up on one (the up hill) ski as you do your turn out.
Staying in the throttle while your turning out helps a lot also, by allowing the sled to turn sharper.
hearnoevil
Can I remove it without cutting it up.
Oh and I caught the whole screw up on video.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
I know it sounds harsh, but turn out earlier. It's better than having to dig out.. I often stand or jump from board to board. Or have my right leg on the left board or vice versa depending on the situation. The more narrow the stance the easier it is to roll.
hearnoevil
I turned out earlier the first run at it, this was my second try. I wanted over the top bad.
sonds
- Oct 7, 2008
- Golden Valley MN
- ductworksmn.com
- 08 T-Nytro
Skinz front end and new track......TS mtn tamer if you can swing it.
Mtnviper
Vendor
hearnoevil said:Can I remove it without cutting it up.
Yes it will come out if you remove the mounts that attach the sway bar to the subframe.
They are held in place with allen head bolts, 6mm I believe. You'll want to use a high quality allen wrench as the bolts are really tight and you don't want to round them out.
Bullitt
Narrow ski stance and removing the sway bar will help alot. Of course you'll need better shocks once the sway bar goes. In my own opinion mountain sleds should not have sway bars. Weight on the uphill side of the sled is a must no matter what sled your riding when turning out.
Alatalo
Change this and there will be no need to turn out...hearnoevil said:This dam mavrick track gotta go
..SNAKEBIT..
Alatalo said:Change this and there will be no need to turn out...hearnoevil said:This dam mavrick track gotta go
X2 162x16x2.5 CE made night and day
hearnoevil
mines 153, they make ce in that length?
isn't cat tracks a direct swap?
judger101
yes they make CE in 153, yes cats are direct swaps
Yamtodd
night and day differance with a CE the best thing i have done to mine.
Off Trail Mike
Gone Riding!
hearnoevil
Its the front end of these nytro's. Spindles are too close to the track. I was doing a major technical (read loosing it meant a roll to the trees) side hill on my xtx and I couldn't get it to stop climbing. Puts you in an aweful postion when you can't bail out or control the climb.
Put the skinz front end on. I did on my 153 and all BS aside, its like two totally different sleds. Predictable and more importantly you can steer it anywhere you want to go.
You would think someone in Yami would notice this and fix it, but thankfully aftermarket exists.
Powerclaw or CE on track choices, but I'd do the front end first, it simply makes the sled a dream to ride.
OTM
OTM
hugger70mtnmax
I agree with OTM wholeheartedly. I find myself doing a lot of things with this front end still centered on the sled that I had to be full on laid out on one side to get it to do before. It makes a big difference in the sled.
