TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
The last 3 years I have been using seafoam start of season then last run, also stored with it.
One ounce per gallon. Took the carb's off just to check them, Totally spotless clean as whsile,
looked like they were just cleaned.
Did find the o-ring on the main jets and float bowls gaskets need to be replaced. Think might use less then
ounce per gallon.
Course broke one of the heater lead wire off. Do not know how to fix that.
Changed screw on bowls to hex head 4mmx12mm
ounce per gallon.
