secondary help
radianguy
Corner Brook Newfoundland, Canada
Canada
2009 Yamaha FX NYTRO XTX 1.75
I took my secondary off tonight to grease the drive shaft and speedo bearings, I took things apart and watched where the spacers/washers went but when I went to put it back together there were 2 thin washers that I didn't see when I took things apart. I have the 3 thicker washers that go on the shaft before the clutch goes on, these 2 are different thicknesses, do they go on the bolt that holds the clutch on?
In the parts fiche I'm thinking they are part #23, so would they just go on before the big washer and bolt?
Thanks for any help.
http://parts.yamaha-motor.com/partimage.gifx?d=95232,2,0,sport
There should be 2 behind the clutch, 2 in front of the clutch and one of different size for the main bolt.
Yes remove bolt, pay attention to order of washers, and reinstall. Nytro is 46 ft/lbs
