Secondary jack shaft bearing differences
Checked out my bearing today.. wow should have done this earlier!
How many miles on it !? Chaincase side ?
2000kms.
This is clutch side. Just have the chaincase apart and that one looked fine, Also oil lubed.
I actually made a mistake earlier, I said the chaincase side went on the race machines but it was actually the clutch side! Because I remember being able to move the clutch up and down about 2 inches ! Should last longer than 2000kms ! I think it's rediculious, not like it's a small job either !
Yeah cheap seal just lets the water in and flush the grease out!
Cheap seal lets the water in and flush the grease out!
For sure ! Pretty essential part that shouldn't be cheaped out on !
There are no other brands that can replace the KOYO bearing that I'm aware of because of the 28mm ID
Ok. When I check It's 28 mm. Never know that before! So sorry I gave you wrong answer.
