Turk
Tech Advisor
Troops
I am just wondering what most guys are using for secondary wrap at 10-12 pounds boost at 1-2k elevation. I have been using a silver at 100 but I think I am gonna play with the white attak spring. Whatcha guys using & hows it working? I have had great success with hc,s & hh,s & now it is time to do some fine tuning with the secondary.
TurboJamie
My setup with silver was 50* wrap @ 9psi boost
With the Pink my wrap is 80* @ 9psi boost
adirondac blue
You gotta run the white 3-3, like ted said. I have run that up to 18lbs.
FastAction
Silver did not work for me either,using white right now grabs way better @80 I think been awhile plus running hh and a roller sec I`m running between 14 and 16lbs boost.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Turk I use an AdvantEdge 51/43 with the white spring at 60 together with the supertips, works great at 12 lbs of boost but even better at 16 lbs.
