semi closed tunnel block off ?
yamafreak
monee IL
well here is my idea. only took a little bit of work. I'LL let you know if it works or not. it is mounted above the tunnel protectors.
I did the exact same thing...even used checker plate also but put the checker side up :bling It works great,less than half of the snow-ice build up than before.You will be glad you did it.
only took about a hour. droped the rear of the suspention and you have a bunch of room. just another reason to go out in the garage and drink beer.[/b]
I have a sheet of aluminum ordered and will be doing some sort of close off along the protectors but I have a tunnel heat exchanger to consider. I like the idea of a partial close off but would like to see some pictures of ice build up with this setup.
I'm pretty positive your going to have issues here. I tried a piece of Royalex where you did... it worked great, until I bottomed out. Luckily I was using royalex and not steel or ^. I'm pretty sure when I hit it would have ripped the track off. I do have studs... but I did a bump check when I got back and it's going to be close up front even with a stock sled.
Anyone have a picture of the plate and dimensions. Are there any bends or just a straight piece of aluminum and some rivets/screws?
that's what I thought above the protectors no problem. It is just a sheet of aluminum. can't remember the size. I will go out in garage tonight and get some numbers.
I purchased a .05" thick 2' X 3' sheet of aluminum that I plan to install on a RTX with a tunnel heat exchanger. I was hoping to see a few pictures of how well the semi closed and fully closed help prevent icing before I do the install. I think doing a full enclosure mounted to the bottom of the protectors would work the best but may be to restricting. The tunnel exchanger has worked well and I don't want to interfere with its ability to dissipate heat so I'm leaning more toward the semi enclosure because it is less restricting. Has anyone done a close off with the tunnel exchanger?
