I change the oil in my sled end of season. can be as much as 3500 miles or as little as 2,000. I change filter as well. Doing the job anyway so do it all.
I ran dino for the first 5,000 or so miles then switched to full syn. Never tried semi. I do know the sled starts easier with the 0-40 synthetic in it and gives me a piece of mind on the 3,500 miles oil change.
Now my truck has OLM system and if I run lots of highway miles it will go as long as 10 to 12,000kms before it thinks its time to change oil. About 6 to 7,000miles. I change it about once a year now with synthetic oil in it. I changed it twice a year with dino oil in it long before the OLM triggered.
Even at 10,000kms or 6,000 miles the oil is not that dirty. Years back on the 60's cars that did not burn anywhere as clean as the newer vehicles I changed every 2,000miles and the oil was black as tar in the winter from the choke cycle every morning.
I'm not worried about a 3,500 mile oil change on my sled. But I do worry about a 7,000 mile filter change like Yami recommends.
As far as the acids go I dump the oil in the spring and fill with fresh so the acids are gone for the summer sleep. I use synthetic for the better viscosity life and easier starting. I see no problem with the semi or even the dino oil.
I do see a problem with changing the oil in the fall and changing the filter every second oil change. Each to thier own and there will be so many different opinions on this that I'd say go with what you think best. But do change the oil and do change the filter. Interval and type of oil is up to you. What Yami recommends is a fine start. Going totally anal about it is fine as well.
Change it every 1,000 miles and new filter every time will only hurt your wallet up front but way less then changing it half as often as Yami recommends.
Different strokes!
