Rx1M5
Do I need to set the base line fuel pressure with the sled running ie: the 5lbs or is this a static pressure with the fuel lines plugged off and the sled not running??
Thanks Rx1M5
Thanks Rx1M5
Rx1M5
Somebody must know the answer to this one I'm thinkin
Rx1M5
Rx1M5
Rx1M5 said:Do I need to set the base line fuel pressure with the sled running ie: the 5lbs or is this a static pressure with the fuel lines plugged off and the sled not running??
Thanks Rx1M5
You'll see the same pressure either way.
Rx1M5
Really, I guess that makes sense. Will fuel pressure at idle affect air fuel ratios at WOT? Thanks
