insane
Installed a stage 2 s/c with arp 10mm head studs, putting on a cometic .060 custom head gasket. Want to run at 10 psi. Does this gasket lower the compression enough to use 91 octane without detonation?
Skydog
I would say yes and one colder set of plugs...
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
That will drop your CR to 9.97:1 and you would need 90.4 octane to be safe. So 91 your good at 10 psi.
That is my exact set up for my 10 psi pump fuelie SC apex and my plan to run 91,92,93 what ever is available
I also plan on carrying some NOS racing octane booster it actually works and might give you a margin of safety if you get to some iffy gas or in a pinch some lower octane and LIGHT throttle to get you to a better fuel station.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Running 91 with 90.4 octane requirement is a tight race with detonation IMO. 92 and 93 would be fine. Add some octane booster (one that actually works) when running 91.
DO NOT attempt to run it on 87, no matter what.
kinger
- Jan 17, 2005
- Clear Lake, IA
Anybody know what the effect of NOS octane boost is say on gas with 10% ethanol? Its common around here that we get 90 octane mid grade that has ethanol, I know the MMT in the octane booster works well in straight gas but not sure how well with a ethanol mix?
Also here is a link to the booster that will take 91 and make it 92.8 octane:
http://www.summitracing.com/parts/PTX-12007
Make SURE its the off road formula, any on road formula will change it less then a 1pt in octane.
Skydog
You have a PC3+IGNITION CONTROLLER can you pull a few degs of timming on big end? 2-3 would be great!! And add 2-3 down low!!
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
rxrider said:Running 91 with 90.4 octane requirement is a tight race with detonation IMO. 92 and 93 would be fine. Add some octane booster (one that actually works) when running 91.
Been there done that..... scraped the engine....
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Thanks MulotTurbo for sharing your costly earnt knowledge with us way back when. I had you in mind writing it, you learnt the hard way so we don't have to. I'm glad to help a fellow sledder from making such a mistake by passing on what I've learnt from you. Sharing our experiences are one of many things that makes TY what it is.
insane
Thanks a ton guys. I would be interested in knowing which octane booster works the best and how many points the best boosts the octane #. I have seen mant posts on this subject and my head is still spinning. Some real world results or some independent lab results would be great. Hey Skydog I am going to start a post on tuning my pc-3 for the s/c as I need some advice on where to start and the correct procedure. Thanks.
heath@mpi
- Aug 20, 2008
you guys should consider Torco it is one of the only additives that actually add multiple points to your octane, It comes in 32 oz cans that can be carried in your back pack or on the sled. it will turn 10 gallons of 91 into 100 oct.
This is a great alternative for places you can only get bad fuel at.
http://torcoracefuel.net/pro-accelerator.html
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
heath@mpi said:you guys should consider Torco it is one of the only additives that actually add multiple points to your octane, It comes in 32 oz cans that can be carried in your back pack or on the sled. it will turn 10 gallons of 91 into 100 oct.
are you sure.... that can will raise octane SO MUCH?????
if that would be true I would have crates of this stuff I guess
Turbor
- Apr 16, 2008
- mirabel,quebec,canada
- sidewinder
want to try it muloth? i have some in stock
Skydog
I have heard good things about it! In the boating world!!
Skydog
Turk
Tech Advisor
Torco fuel accelerator...used it & it is the only octane boost that really works. it is actually concentrated race fuel.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
turbor said:want to try it muloth? i have some in stock![]()
Will try it on my rx1 mountain which runs on 91 octane.
So will fill de tank with 87 octane, then pour this bottle into it, then go out in the field..
are you willing to pay engine damage if it goes kaboom?
