setup
marc
mississauga,ont
Hey guys,
Would like to know what is the best setup is as far as limiter straps, transfer rods. Looking for great pull out of the hole but not somuch that slider wear becomes a problem. The way its setup now I think my straps are half way, transfer rods are wided open. Went out over new years and had to replace my sliders after 150kms. My dealer did the setup when it went in for sevice back in late nov. I have had my sled 03 RX1 for three years and always go have to replace the sliders maybe I been doing something wrong. any input would be great....Thanks. :yam: :yam:
Put extrovert drivers on, Run track a little looser, Transfer rods loose, Limiter straps about 7/8 to 1 inch of thread through nut, Front suspension springs soft as they go, Depending on amount of studs you should hook up pretty well and still be able to get around corners ;)!
running new ripsaw track with 96 studs down the middle. So run the limiter straps with 1 inch of thread through the top nut, transfer rods run wide open and the track loose is this right....thanks for the info.... :D :D
Your still going to have slider wear if your in marginal conditions, Also on mine I punched the extra holes in my track and add the rest of the clips, Ya it adds more weight but with 192 studs a little more weight plants the A$$ end a little better giving awsome hole shots.
More preload on the front springs will increase transfer and decrease push through the corners.
