DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I just put a TD fuel pump in a buddies sled and it had an oitiker clamp on both ends of the supplied flexible hose.I sure am glad I tested a few miles from the house. Could you imagine this have been in 0° temps and having to try to do this outside. Sorry guys, my bad...
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Was it the plastic line or rubber?I just put a TD fuel pump in a buddies sled and it had an oitiker clamp on both ends of the supplied flexible hose.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
No, it was still attached. Basically it was hanging off the last Barb.Was the fuel line off when you opened it up?
I reinstalled it, hit it with a dose of heat (to further shrink) and now I will add clamps.
Thoughts ?
Jon, my fear is I did not heat it up enough. When I installed it I couldn't get it soft enough to go all the way past the top Barb.Wondering if you heated the plastic to much when installing ?
That flexible plastic is very delicate.
I haven't added the extra filter yet. However I do understand the advantages.Just spitballing, did you add a fuel filter?
And who is this Doc Harley, what did he do with JT lol
Who?!?! When running from the law, it's best to clean up all traces that somebody or something existed. Lol.
Always on the move....
Doc Harley
- Oct 17, 2016
- Here & there
I was able to reattach and then reheat the area in hopes that it would bind better. But I'm going to the store to get clamps.I just put a TD fuel pump in a buddies sled and it had an oitiker clamp on both ends of the supplied flexible hose.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
SNUG on the clamps.. Not torqued to shi^%.. Its plastic not rubber so you cant go crazy with the clamps.. Goes without saying, just saying..I was able to reattach and then reheat the area in hopes that it would bind better. But I'm going to the store to get clamps.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Myself I wouldn't be using that plastic hose even with clamps, but thats just me. I like the submersible rubber hose with a clamp that is going to hold the rubber decent.
I'm not sure putting a clamp on that plastic is going to seal it up. Heating that plastic and expecting it hold the pressure IMO is a hit and miss. If it come off on a trail ride there you are broke down on the edge of the trail. I've not ever had a submersible rubber hose fail or come off, just my opinion.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
It took me a minute to figure this out!Just spitballing, did you add a fuel filter?
Doc Harley
- Oct 17, 2016
- Here & there
Knapp, do these get gapped?
rev them up
- Apr 3, 2006
- Prince Edward Island, Canada
- 2011 Nytro XTX, Hurricane Exhaust, K&N, Pcv, Autotune, Pod300, Star Suspension,
2018 Sidewinder, TD Max Spool 17, CAI, TD 3 Inch Stock Muffler Mod, 3Bar, BOV
Yes they do, td recommends. .020
KnappAttack
- Feb 19, 2004
- Welch MN
I run them at the factory gap of .024"-.025". I've had no misfires with them in many years at that gap. I've not seen a need for less gap that with less than 320-330 or so HP. In the old days with some sleds with weak ignitions it was needed, but I haven't seen misfires on the 998 yet, not sure why TD would recommend it myself for trail use tunes.
If you desire to gap them tighter approach with caution, if you gap them less than desired, you don't want to then open the gap up by prying against the center electrode and cracking the insulator. NEVER PRY AGAINST THE CENTER ELECTRODE!!!!!
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
If you do gap them to .020, tap them on something hard like steel and check and repeat. I gapped mine this year, but never had a misfire either at stock gap.
Glad to hear your sled is an easy fix!
Doc Harley
- Oct 17, 2016
- Here & there
Left factory gap at .024 for this low boost application. For reasons Knapp explained. I didn't install the plastic flex line to the pump lid correctly, my bad. I'm a little wiser today. no harm, no fowl.
Sleds back in business....
Zero contact with 1.63" studs and heat exchangers.
Very thankful to the group of guys whom gave any and all suggestions.
Now....snows coming in as we speak, let's go tear some $*** up!!
BTW.... My 35-year untarnished reputation still stands... I always make it back. Haha!!
Peace.....
Peace.....
DMCTurbo
- Nov 12, 2005
That's why this forum is so great! Glad your back up and running!Left factory gap at .024 for this low boost application. For reasons Knapp explained. I didn't install the plastic flex line to the pump lid correctly, my bad. I'm a little wiser today. no harm, no fowl.
BTW.... My 35-year unturned reputation still stands... I always make it back. Haha!!
Peace.....
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
if you dont mind taking apart again... get rid of that plastic hose and put submersible fuel injection rubber hose on with clamps.
Doc Harley
- Oct 17, 2016
- Here & there
I got this....lol. I ordered more of it so I can get practice.if you dont mind taking apart again... get rid of that plastic hose and put submersible fuel injection rubber hose on with clamps.
- 6K
