Sheared Driveshaft on 2017 sidewinder
how are you installing the bearing tho? a .001 interference fit is still an interference fit, are you hammering it on? i just cant see how you can line it up with the pin and then hammer the crap out of it., maybe if you had a long rod and ran it through the other side and pulled it on, but lining up that tight tolerance pin must be quite the ordeal, especially if you mis align it.
the bearing is already pressed in to the brake housing and the pin in shaft was placed at 90 degrees (as viewed from caliper housing clock wise) we indexed the slotted inner race to 90 degrees and slowly drew this together with the 3 bolts,checking alignment with a inspection mirror.
Wow, I'm pretty sure I would come up with a few new swear words doing that. Good on you!
I bet if I bothered to calulate it (for old times sake) you could use liquid nitrogen to shrink it as well
That would need to be a press fit, right? Shaft being .0003 larger than the bearing I.D. is not sliding on.
How are you going to press the caliper on the shaft? Caliper with bearing is the last to go on.
I had my driveshaft spray welded to fix issue. Bearing presses onto shaft. 0008 interference fit. Problem solved.
Built tool to press onto track shaft (which is hollow). Threaded rod of tool goes through to chain case side. Start caliper housing w bearing onto shaft, then tighten nuts on threaded rod to press on. Works great.
How do you get the caliper off when servicing the bearing?
Would have to make a puller that mounts to the 3 holes in the caliper house - heat it and pull it off the shaft.
Some guys have made them after green loctiting the bearing on the shaft.
MS
MS
Travis at BOP posted a template for a puller some time ago. Works great. Cat pn 0744-067 is pretty much same.
