Psycho Dave
- Jan 8, 2013
- Norderåsen
- Sweden
- 2021 Arctic Cat Riot X
1986 Aktiv Karibo
I'm changing the jack shaft bearings and drive belt on my RS Viking Professional. So before I start using the new belt I'm going to check the sheave offset so everything is as it should. Since I don't have the service manual I have to ask, does anybody know the interval for the sheave offset (in mm if possible)?
Psycho Dave
- Jan 8, 2013
- Norderåsen
- Sweden
1986 Aktiv Karibo
I can answer myself, 13.5 ~ 16.5 mm (0.53 ~ 0.65 in)
Katannilik1
- Jan 14, 2015
- Kimmirut
- 2005 VK540, 2010 VKPro, 2014 Viper
I know you already found the specs you need, but for the future you can also check out the TY Tech section at the top of the page here. There is an awesome amount of information in there.
Psycho Dave
- Jan 8, 2013
- Norderåsen
- Sweden
1986 Aktiv Karibo
Yes and it said 15 mm exact, since I know that they usually specify an interval I did not trust it. It turned out that the interval which I wrote above was written in the least read book, the manual.
