breakinbarrs
- Dec 31, 2007
- Not North Enough,Ashburnham MA
Press the mode button to go from hand warmers to rear shock adjustment but will not change from warmers. Is this a sign that the infamous wire has been disconnected?
fourload
Yep. I have done it on mine 3 times.....
quebec#1
Could also be a fuse or a internal problem with the cluster guage !
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
Most likely the wire. If you have your manual, be sure the wires are routed correctly when repaired. Some seem to have more issues than others, but if the wire is secured correctly and out of harm's way, it should hold up just fine.
quebec#1
My fuse went and i replaced it last weekend everything works fine !
Crazy dealer said it was the cluster guage !
- 11K
