Shock Removal Help Needed
I definately need bushings and rear bogie wheels. The orig bogie wheels have a couple slight cracks in them with only 2400miles. Is this normal?
Should I invest in billet wheels? Did the wheels crack because of the worn bushings and movement in the back of the skid?
Should I buy factory bushings or is there a better option?
<<the front arms are prone to cracking>>
Is there a preventative fix for this? Welding gussets? Any pics?
Will
I would get the spoke style yamaha wheels, or the x wheels......unless you want to spend extra on some billet bling. The x wheels are about .3 inch bigger diameter for improved hyfax wear. For suspension crack,do the beef up kit and powder coat by welteracer.
Is there a preventative fix for this? Welding gussets? Any pics?Will
http://www.ty4stroke.com/viewtopic.php?t=74254
Wheel/shaft removal
How do I remove these wheels and shaft?
Re: Wheel/shaft removal
They are press fit so you will need a puller.
I was hoping to do mine as well but they surprisingly still spun smooth so I left them.
I have just under 5000 km's on my sled and they are holding up good but I am sure sometime down the road they will need some mtce.
My regular gear puller won't work. The "lips" of the puller are not long enough to reach around the back to solid plastic. It will only grab the rubber which will surely tear/rip it.
Any suggestions?
Will
Any suggestions?
Will
Got a hyd. press??
step 1- put a block of wood over the aluminum shaft and whack it a few times with a big fn hammer. this will drive it right through the pressed on wheel.
step 2 - once one wheel is off remove the shaft with the 2nd wheel still pressed on it. put some blocks of wood under each side of the wheel untill the alum shaft is off the ground then repeat step 1
Panterawill said:
Great! A few good shots and came right off.
I'll have to remember that, thanks for the tip ;)!
