Offroadin
- Jan 17, 2015
- South of Ottawa
- 2017 Sidewinder LTX-LE,
Woody's/BOP/UNT/Sentinel guards&LED/LinQ
Fyi' ltx-le
Has only been driven off the trailer and moved around in the shop.
Haven't had allot of time to work on it however this week i was moving it and noticed 3 bearing lying on the floor next to the sled.
Then, when i was looking around to see where they might have come from, i noticed a part quite loose. It looks to be like a support bar that runs parrallel to the rear shock.
Sent from my iPad using Tapatalk HD
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I have basically the same suspension in my viper and I haven't seen anything like that in there !
Offroadin
- Jan 17, 2015
- South of Ottawa
Updated with a better video
josnow
- Dec 12, 2014
- CMass
- 2005 Rage
How are you moving around the shop? Using dollies? Using a creeper in the shop? Saw something similar on here recently and it ended up being bearings from the creeper wheels.
benjamingvsu
- Oct 9, 2007
- Stevensville, Michigan
- 2014 Viper rtx se
Someone else on the forum had this bearing issue, they ended up beeing from a creeper he used in the garage. so check your dollys, creeper or jacks that might have bearings. as far as that suspension piece I'm not sure, maybe a plastic bushing is supposed to hold it tighter. not sure I'd worry though.
Offroadin
- Jan 17, 2015
- South of Ottawa
interesting.. It might be that. I do use dollies from time to time or just lift it around.
WRG to the loose part, it's noisy as hell when moving it (I finally just took it out for the first time here..). It is quite audible. I am bringing the sled in to where i bought it this evening to get studs installed, so will bring it to their attention... Thanks all.
Offroadin
- Jan 17, 2015
- South of Ottawa
Ended up being bearings off one of my dollies
WRG to that loose bar, the dealership is going to look into it.....
You must have them PA dollies. They are a pile of
I had three sets and they all did the same thing.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
The loose linkage fit is normal!
