AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
I for the life of me can't remember what site I saw that on. But after searching some more it looks like that float plate is for the vipers. Maybe it works on the winder also? I am guessing it fits right up to the bumper to help snow from getting behind the bumper? I dunno. Here is the p/n: SMA-8KC34-00-BK On the Canada site it says "Does not fit up with optional accessory front bumpers" So it might not work on the winder. I'm guessing wherever I saw it had incorrect info listed.
Update: I just saw this. It's for a viper. If that won't work on the winder I wonder if they will be coming out with one. http://www.sledsolutions.com/index.php?id_product=298&controller=product
Mr. Sled; It might be another place interested in becoming an advertiser? I have nothing to do w/them. It was just something I came across. If posting this goes against anything feel free to delete it.
![599-tm_thickbox_default.jpg](/proxy.php?image=http%3A%2F%2Fwww.sledsolutions.com%2Fimg%2Fp%2F5%2F9%2F9%2F599-tm_thickbox_default.jpg&hash=b524ebf85af60e6b279a5d9e6d3797e4)
Does anyone know yet if the viper rear skid plate fits the winders?
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
have the same bag on a 137 Winder. EXCEPT its the next size down I believe
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
I doubt it for the RTX, it goes right into the seat wedge.That bag is a definite maybe Do you think it could be mounted if a Roto pax gas can was underneath of it ?
dgjr636
After a few mods we are making the Up North Tech linQ double mount system work on the Sidewinder. Ken at Up North tech is working on a mount that will not need any modifications. Should be done early December. There's nothing like being able snap fuel caddy or bags on and off quickly.
Pstn head
How about the rack itself, will it be able to snap on and off of the tunnel easily ? And will it fit the 129" ?
![](/styles/donate.gif)
3UR
- Oct 23, 2016
- Pennsylvania
- 2017 Sidewinder LTX-LE
2016 Arictic Cat 7000
2012 Skidoo MXZ TNT 800
- NE Pennsylvania
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
What mount kit did you use for this same setup I wantHere's my fuel caddy with stackable bag
View attachment 122222 View attachment 122223 View attachment 122224 View attachment 122225 View attachment 122226
Sent from my SM-G920W8 using Tapatalk
marathon mike
View attachment 122217 View attachment 122211 View attachment 122212 View attachment 122214
Will the new larger gas caddy fit and a bag behind or front with this rack?
AXR
- May 5, 2007
- Central NY
x2???¿¿¿???What mount kit did you use for this same setup I want
dgjr636
He is using the LMP-1 bracket from Up North Tech
dgjr636
Not on a 137. The larger tank is taller and longer. On a 137 can only use the 3 gallon tank with the small or medium bag behind.
You can use the single LMP-1 mount with the larger 4 gallon tank and stack the small, medium or the new Sr21 bag on top.
AXR
- May 5, 2007
- Central NY
Awesome!
3UR
- Oct 23, 2016
- Pennsylvania
- NE Pennsylvania
LMP-1-B it is listed for viper and ZR. No issues with heat exchangers
I also added skidoo tunnel stickers to adapter. I don't think you need them but I had a set from my skidoo they are 10 bucks. You can see them on the pic of the bracket.
It keeps the bottom of the linq accessory from rubbing through finish. I have to tell you the finish on the bracket is incredibly durable. Proven after my kid dropped it and it skidded across the concrete floor... no damage at all
AXR
- May 5, 2007
- Central NY
I was thinking of putting some Scotch 1 in. x 10 ft. x 0.065 in. 2228 Rubber Mastic Electrical Tape under the bracket. It's a tough rubber tape that sticks to itself. I always wrap my bars with it before attaching ram mounts. Keeps the finish nice once removed.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
SkiDoo has great accessories
Can the smaller tank stack the Sr21 bag on top? That would be close to perfect for me.
