Eugenius.w
- Feb 12, 2019
- Denare Beach
- Yamaha Sidewinder BTX
I’m having issues when I hit the throttle at the start, it lifts up the skis hard to about 50 mph cuts out for a second then full power for about a second and a half then cuts out again for a second. If I gradually pick up speed and then hit at 60mph it will pull hard all the way to 110mph without cutting out. Any ideas where to look. I’ve eliminated the roll over valve. Put a second clamp on the cold air intake by the turbo. Checked for moisture in the vacuum lines at the sensors. Cleaned out about a table spoon of watery sludge from the air cooler. Where do I look next. Could it be a faulty sensor?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Sounds like a fuel delivery issue
Eugenius.w
- Feb 12, 2019
- Denare Beach
I don’t understand how it could be a fuel delivery issue when it still pulls hard after it cuts out. Or if you roll it up to 60 mph then squeeze it and it pulls hard to 110 mph.Sounds like a fuel delivery issue
Try with full tank to know.I don’t understand how it could be a fuel delivery issue when it still pulls hard after it cuts out. Or if you roll it up to 60 mph then squeeze it and it pulls hard to 110 mph.
Your rate of acceleration is higher at slower speeds.I don’t understand how it could be a fuel delivery issue when it still pulls hard after it cuts out. Or if you roll it up to 60 mph then squeeze it and it pulls hard to 110 mph.
Eugenius.w
- Feb 12, 2019
- Denare Beach
I did have a full tank of premium fuelTry with full tank to know.
Ok, I'm not sure what it could be then.I did have a full tank of premium fuel
Is it tuned?
Eugenius.w
- Feb 12, 2019
- Denare Beach
Yes I agreeYour rate of acceleration is higher at slower speeds.
Eugenius.w
- Feb 12, 2019
- Denare Beach
I have a MBRP performance exhaust. That it.Is it tuned?
I'm not sure which version you have on it, but it could be causing knock protection to activate possibly...?I have a MBRP performance exhaust. That it.
Eugenius.w
- Feb 12, 2019
- Denare Beach
I could install the old exhaust and see if that eliminates the problem.I'm not sure which version you have on it, but it could be causing knock protection to activate possibly...?
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
High flow muffler on stock tune could be over boosting. Ecu don’t like it and cuts out. Try stock muffler if goes away that is very likely what it is.I could install the old exhaust and see if that eliminates the problem.
One other thing that could be happening is that you are tapping the rev limiter.
Eugenius.w
- Feb 12, 2019
- Denare Beach
Thanks I will try the old muffler tomorrowHigh flow muffler on stock tune could be over boosting. Ecu don’t like it and cuts out. Try stock muffler if goes away that is very likely what it is.
