Gman25
- Dec 11, 2019
- ottawa
- 2018 sidewinder ltx
1999 srx 70
1993 vmax 750
Ok guys thx got myself a good asortment of various thicknes washers from a brg shop so i will be able to take out all the freeplay slop by shimming back side of gear
Now upon re install what method is best for servo install i used yamaha service manual last time.
thx all
And especially godspeedswe for your shimming idea
thx all
GodSpeedSWE
- Jul 30, 2019
- Polarcircle
- Sweden
- -19 AC XF9000 HC
thx all
You are welcome.
Dont forget to weld the torx heads on the tentioner.
Turboflash
- Mar 18, 2019
- Southern MN
While shimming, you may want to check to see how far out of line your top gear is with bottom gear. I've not shimmed so I don't know how much it takes. Good news is, on the 998s I've looked at, the top gear needs usually needs to be shimmed out more to be in line with bottom gear anyway. But, worth checking while you're at it.
birdman22
- Dec 11, 2018
- Mi
- Sidewinder RTX Le 50th- 18
Nytro- 12
Apex-08
Sounds a lot like my situation Sunday doing about same speed.
Dealer said it needed the shifting fork shoes and upper bearings amongst other items.
Fast
- Sep 25, 2018
Is this on the older sleds or is this needed on the 19's & 20'sI put an aditional shim behind the upper sprocket to eliminate the huge axial play. A standard shim need to be skimmed down about 0.4mm to fit. Gives better engagement and 100% straight chain. Some people also change the bushing to a SKF version.
Also spotweld both bolts on the tentioner since its a common point of faliure.
GodSpeedSWE
- Jul 30, 2019
- Polarcircle
- Sweden
- -19 AC XF9000 HC
Mine is a 2019 and they where both loose.
GodSpeedSWE
- Jul 30, 2019
- Polarcircle
- Sweden
- -19 AC XF9000 HC
My chain is straight as an arrow when shimmed. Seems like it is the natural position for the chain.
Turbo, how would you move it? It is stuck between two clips. I've just added the Yamaha .5mm washer behind the gear like others, but still leave the stock 1mm thrust washer on each side.While shimming, you may want to check to see how far out of line your top gear is with bottom gear. I've not shimmed so I don't know how much it takes. Good news is, on the 998s I've looked at, the top gear needs usually needs to be shimmed out more to be in line with bottom gear anyway. But, worth checking while you're at it.
Fast
- Sep 25, 2018
Ok thanks i remember doing this on all my poos, line it up with a straight edge and shim accordinglyMine is a 2019 and they where both loose.
Turboflash
- Mar 18, 2019
- Southern MN
Can't move it much between the two snap rings. Thinner or thicker shims.Turbo, how would you move it? It is stuck between two clips. I've just added the Yamaha .5mm washer behind the gear like others, but still leave the stock 1mm thrust washer on each side.
scooterwj
- Dec 4, 2008
- Hell, Michigan
- 2018 SW
thx all
I've always followed the procedure in the service manual for installing the servo... Never had an issue
