jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
- 2010 RS VECTOR GT LTX STOCK FOR NOW!
HEY GUYS I HAVE A SET OF THESE ON MY 03 RX1 I BOUGHT AND WAS JUST WONDERING WHAT KIND OF CARBIDES YOU HAVE TO BUY SO I CAN REPLACE THEM.. IS THERE A MODEL TO REFERENCE SO I CAN BUY ANY BRAND OF CARBIDES. IM A LITTLE CONFUSED. IT HAS 2 ON EACH SKI ALSO WHAT DO YOU GUYS RECOMEND FOR LENGTH OF CARBIDE FOR AGRESSIVE TRAIL RIDING? ALSO DO YOU RUN ALL THE SAME ON ALL FOUR OR CAN YOU RUN DIFFRENT ONES ON THE INSIDE AND OUT.
THANKS FOR THE HELP!!!!!!! WHERES ALL THE SNOW!!!!!!!!
RXMax
I only know of 2 models. Right from Simmons directly or you can run Stud-Boy shaper bars. They list a part number in most catalogs for Flexi-ski application. I run the Simmons on mine. 4" of carbide on both bars per ski. Simmons makes just a hard bar with no carbide you can run on one of them if you so choose.
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
Roetin makes a kit and Rider's choice from Shadetree also has them. try western power sports.
I am running the 6" stud boy shapers on all four, and so far so good.
The guy on ebay has them up to 8" and they are much cheaper. I can't remember the name but he's the only one if you search sled parts - simmons. I think I just pd $ 59 for new 8" pr.
For high preformance with 13mm sway bar I run 8" on outside and 6" on inside. Hammer down and just hold on in the turns
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
I had Simmons on my 03 RX1. I ran 4" stock carbides on the outside edge and 6" Bergstrom Triple Points on the inside edge. Lots of people used this set up and it worked for them.
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
THANKS GUYS SOUNDS GOOD IM GOING TO CHECK ON YOUR LEADS!
thinksnow
Arctic Cat also has a part number for replacement carbides. My trailer is 30 miles from me so I can't supply the part number. These are on really thick heavy duty bars and wear really well.
It is johnmaster enterprises and they are still $59 + shipping. I have had great success with them as far as wearing. I think I have a pr on the red 05 with 2000 miles on them and they are still good to go.
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
I SEARCHED EBAY AND I SAW THOSE FROM JOHNMASTER I THIK ILL GIVE THEM A SHOT. THANKS JDP
