porkchop
cannondale27 said:Its tough to do it right but if you can get corner speed right before the corner then use steady throttle through the corner it helps also.Giving it gas or letting off in the corner really upsets chassis and it wont corner flat.
That is exactly my problem, it just doesn't want to take the corner good.
Thanks for the input
Vermonter
snofreak500 said:i have found with my Gytr clickers that the compression on the skis is key to my lift higher compression/ higher downforce on skis gives me less lift but as long as its manageable lift i wouldn't be scared of it you wont roll its the sway bar and your shock compressing causing the other to attempt to follow suit. as long as its not crazy lift your okay
Well most of the time it's not real bad but there have been a few times when I thought I was going to crash because of it.
yam177
BombaPolaYama
And it looks real professional!! As long as it works!!yam177 said:I like to freak peopl on and realy lean on the sled and ride past them on one ski..... LOL its my amusement on the trail
BombaPolaYama
I have it on order and will be the first to try it on a VL. Will definitely give a report. Schmidt Bros are very confident in it working and I may keep my sled for awhile so I decided to take the chance.snofreak500 said:If you really want some help with ski lift aside from adjusting like some money to make your sled handle better and not lift so much go with the Schmidtbros Sway Bar Kit it will help you i believe.
yam177
BombaPolaYama said:And it looks real professional!! As long as it works!!yam177 said:I like to freak peopl on and realy lean on the sled and ride past them on one ski..... LOL its my amusement on the trail
LOL I only do it in wide open areas with at least 10 feet between sleds. Wouldn't want to put anyone in a bad sport but the looks are priceless!
yam177
BombaPolaYama said:I have it on order and will be the first to try it on a VL. Will definitely give a report. Schmidt Bros are very confident in it working and I may keep my sled for awhile so I decided to take the chance.snofreak500 said:If you really want some help with ski lift aside from adjusting like some money to make your sled handle better and not lift so much go with the Schmidtbros Sway Bar Kit it will help you i believe.
BTW mod sled is getting pieced out I will sell you a used one we tested it for 4 races
phazerhawkdude
I had the ski lift problem too. I put fox floats on the front with about 65 lbs in em and pulled the sway bar. Handles like a champ now.
phazerwi
How much are you selling it for? and are all the parts there?
I may be interested......
mtotguy
- Jan 20, 2011
- Montague, Michigan
- 2016 Rush 800, 2014 Viper RTX, 1983 Excel 3
Use the brake
In addition to getting the suspension tuned, a trick I use is to tap the brake. When that inside ski starts to come up you can pull it back down with a tap on the brake. When I'm really jammin thru the tight stuff I never take my finger off the brake lever. Sometimes I'm on the throttle and the brake at the same time. The down side is that I can roach a set of brake pads pretty fast.
phaze5
i am more of a overcome and adapt type rider must be ,
i actually like the front end doing its thing myself, it must scare the hell out of people though, i figure they must back off thinking i am in crash mode haha and that gives me the room to run away lol
i actually lift the ski to miss the bad parts in the trails, that is a good thing imo you just have to get used to it, and once ya do your good to go.
just take it easy and it will come to you no need to learn overnight. it takes years imo think about how much actual seat time ya get before you are off it again, every year ya learn a little more and then ya relearn the next year.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
phaze5 said:i actually lift the ski to miss the bad parts in the trails, that is a good thing imo you just have to get used to it, and once ya do your good to go.
X2 I do this all the time, I always hear about how much it looked like i was going all the way over at the next break spot.
phaze5
kinda like your avy pic lol
- Nov 1, 2009
- 2009 Phazer RTX
phaze5 said:kinda like your avy pic lol
lol i was actually trying to turn around to help get my dad unstuck, was not aware there was a ditch...
Vermonter
just take it easy and it will come to you no need to learn overnight. it takes years imo think about how much actual seat time ya get before you are off it again, every year ya learn a little more and then ya relearn the next year.[/quote]
I will agree with you on that. Each year (this being my second) I'm learning and getting better but it can be a little unnerving at times to be taking a fast left hander (or right hand turn)and the left ski lifts and the sled feels like it wants to spit you off. It hasn't actually done that but it will get the heart pumping. I still need to make some of the adjustments to my sled that others have recommended and go out and try it. I'm hoping to do that next weekend.
- 47K
