mr. shide
sounds simple enough. thanks
ecopter
This is another example of Yamaha having their head up their butts. Why not just manufacture the sled with threaded inserts already in place like they did on the Phazers?
Simply amazing.....
jf
Simply amazing.....
jf
mr. shide
agreed. there are a lot of parts/accesories that dont cost too much extra that should be factory equipment.
LJ 452
The OEM ones fail because they are aluminum. Not real durable and will eventially pull out with the ice expansion. I used steel ones (the same used on most autos) and they have held up fine so far.
rindtj
I am confused. Do the skid plates come with the rubber rivets? I guess I understood that they didn't, however, I bought a skid plate from Port Yamaha and the installation kit has the rubber rivets in it? Is the problem with these things in addition to the lack of rubber rivets, or are the rivets one solution to the problem?
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
rindtj said:I am confused. Do the skid plates come with the rubber rivets? I guess I understood that they didn't, however, I bought a skid plate from Port Yamaha and the installation kit has the rubber rivets in it? Is the problem with these things in addition to the lack of rubber rivets, or are the rivets one solution to the problem?
Yamaha must have changed their anchors to rubber, consider yourself lucky as I recently purchased a kit and it came with the aluminum riv nuts.
You shouldn't have any issues with the rubber riv nuts, they will grab and hold if installed correctly.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
the original kit came with aluminum rivnuts.....the fix Ive used for years now being mentioned is a rubber wellnut...
either yamaha has switched or port is setting it up right from the start..
gun nut
After installing rivnuts, add a few 1/4" bolts next to rivnuts. Just drill and tap holes for bolts. Watch out for hose in belly.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
gun nut said:After installing rivnuts, add a few 1/4" bolts next to rivnuts. Just drill and tap holes for bolts. Watch out for hose in belly.
why go through all that... just use the larger rubber wellnuts...
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
sj said:gun nut said:After installing rivnuts, add a few 1/4" bolts next to rivnuts. Just drill and tap holes for bolts. Watch out for hose in belly.
X2
rindtj
Sorry guys, no rubber rivnuts, the same ones you all have described. I am not home and had the skid plate picked up for, got my wires crossed with my dad.
My bad.
My bad.
