stinx
Does anybody know the Part number for the hardware used to mount a skid plate to an attak? I need the threads that you screw into the belly pan. 2 of the 4 in the kit stripped when I installed them. Assanine set up. anybody know an other source to get these inserts? IM sure when I call my two local stealers,they wont have the hardware, but will have no problem telling me to buy another skid plate from them.
sobfrogg
SMA-8FA34-MT-KT
That is the # for the 06 Kit. The inserts are available from McMaster Carr or Grainger.
Try a good auto parts store like Napa they should have them.
When you get the new inserts make sure the top of the tool that came with the kit does not get smooshed.
The tool should slide freely on the screw. If it does not you will smoosh the new inserts.
Take a drill bit or a small file and open the hole up so the small bolt that is used to install the inserts slides freely in the tool.
Good luck
Good luck
- 146K
