blew by you
Will the yamaha ultra skid plate interfere with changing the oil filter?Does anybody have any suggestions on skid plates?I'm not a big fan of the look that the flotation skid plate gives the machine.
Nitrousman1 said:I have the Yamaha skid plate and you have to unbolt it to change the oil. It uses the same 4 screws that bolt the cover on but you have to unbolt the 2 screws up in the nose under the bumper.
blew by you said:Will the yamaha ultra skid plate interfere with changing the oil filter?Does anybody have any suggestions on skid plates?I'm not a big fan of the look that the flotation skid plate gives the machine.
Roest said:Nitrousman1 said:I have the Yamaha skid plate and you have to unbolt it to change the oil. It uses the same 4 screws that bolt the cover on but you have to unbolt the 2 screws up in the nose under the bumper.
When you install a Yamaha skidplate do you leave the original plastic sump cover in place or do you leave it off?
NyTrOMaNIaC said:Roest said:Nitrousman1 said:I have the Yamaha skid plate and you have to unbolt it to change the oil. It uses the same 4 screws that bolt the cover on but you have to unbolt the 2 screws up in the nose under the bumper.
Leave it on and install the skid plate over it.
Roest said:NyTrOMaNIaC said:Roest said:Nitrousman1 said:I have the Yamaha skid plate and you have to unbolt it to change the oil. It uses the same 4 screws that bolt the cover on but you have to unbolt the 2 screws up in the nose under the bumper.
Thanks, anyone have any idea what the Yamaha skidplate weighs?
drwhiskey said:Did anyone ever figure out how to stop the ice build-up issue in the yamaha skid plate. The ice would bulge the skid plate so bad is would fall off. I tried drilling holes in the skid plate and sealing of the engine compartment but it didnt work. Any idea's??
