Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
2016 ltx-se,want to remove the rear skid,do I have to unbolt the torsion springs where they bolt to the rails then just drop the 4 suspension bolts and pull it out?I'm assuming I have to get the backend raised fairly high?looks like it might be tricky getting those spring bolts lined up ,
Yep. Thats how it comes out. Cam the springs down to full soft and then pull the front mounts on spring to rail mount, rotate spring to release the tension on the cam blocks then pull the 4 bolts and the entire skid fall right out.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
LTX-SE. Only need to pull back two bolts. Front is "slide action" and slips over shaft, or am I missing something?Yep. Thats how it comes out. Cam the springs down to full soft and then pull the front mounts on spring to rail mount, rotate spring to release the tension on the cam blocks then pull the 4 bolts and the entire skid fall right out.
I have 2 of them and it's way easier to pull the shaft. You can also inspect the front cross shaft for damage.
kimcoop1324
I pulled the front shaft out and the 2 rear bolts and removed skid. I then installed the steel sleeve that Travis sells at Bop over the factory cheap shaft which strengthens the front shaft and keeps it from bending. The sled is on a lift and the skid is back inside the track but I can't get the front of skid to connect to shaft. I am slightly in front of shaft and need to be slightly behind it. What am I doing wrong? This looks easy but it's a pain in the #*$&@. I tried lowering and raising the rear of skid but it doesn't seem to help. Any help would be appreciated. Thanks mike.I have 2 of them and it's way easier to pull the shaft. You can also inspect the front cross shaft for damage.
Carla 123
- Feb 27, 2017
- Lester beach
You need someone pulling on the track and skid while you line up the front of the skid.with 2 people it works bestI pulled the front shaft out and the 2 rear bolts and removed skid. I then installed the steel sleeve that Travis sells at Bop over the factory cheap shaft which strengthens the front shaft and keeps it from bending. The sled is on a lift and the skid is back inside the track but I can't get the front of skid to connect to shaft. I am slightly in front of shaft and need to be slightly behind it. What am I doing wrong? This looks easy but it's a pain in the #*$&@. I tried lowering and raising the rear of skid but it doesn't seem to help. Any help would be appreciated. Thanks mike.
kimcoop1324
I am going to try a racket strap attached to my garage wall and pipe going thru the rear skid wheels. Thanks for your help
Carla 123
- Feb 27, 2017
- Lester beach
That might work but just get a friend to help.its a pain but once you do it once it gets easier
Unhook the springs on each side and fold the springs back. Also it’s much easier to pull that front shaft and put it into the suspension. I just installed one in my ltx last night alone.
kimcoop1324
I was going to undo the torsion springs if I couldn't get it to get behind front shaft. The problem I will have if I remove the shaft is getting 3 washers back on between tunnel and shaft on each end while trying to hold up skid and track
What washers? I dont have any washers on my front arm Shaft?I was going to undo the torsion springs if I couldn't get it to get behind front shaft. The problem I will have if I remove the shaft is getting 3 washers back on between tunnel and shaft on each end while trying to hold up skid and track
kimcoop1324
I installed the bop steel shaft sleeve that slides over cheap aluminum factory shaft. The collars on the factory shaft end are eliminated therefore leaving slight space in which 2 washers are added on each end to fill gap. I got it together last night using a pipe thru my rear wheels and a rachet strap attached to the wall behind sled. Just enough tension to engage front slides on shaft.
