2008 Nytro RTX
i did forget to put the plug in my fault,I found my old plugs and threw him in and it fired right up and sounded good. you were right its the plugs
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
2008 Nytro RTX
Thanks man,One more thing...could you put 2 different plugs? like 2 of the aftermarket n 1 stock one and run it for 10-20 mins just to make sure its running without hurting the motor?
- Nov 1, 2009
- 2009 Phazer RTX
not 100% sure how different are the plugs?
2008 Nytro RTX
well if you know cr9E and cr10 E i believe,They are both for the sled two is the stock one and 1 is the NGK plug that gives you a little extra HP
- Nov 1, 2009
- 2009 Phazer RTX
I am sure it would be fine, i would wait for someones else's opinion though.
2008 Nytro RTX
Yea I will.,Once these roads clear up ill get better plugs,but right now I can't
- Nov 1, 2009
- 2009 Phazer RTX
2008 Nytro RTX said:Yea I will.,Once these roads clear up ill get better plugs,but right now I can't
Lucky you, They where calling for 18" of snow here last week and not its gona be rain
