martin63092
fuel pump works every thing. if i turn my key on so the fuel pump can start then shut it down then start her back up so the fuel pump goes on again and then i close it it will backfire when i close my key. something is wrong here.
sorry for my writting, im french
Sounds like you are not getting fuel to the injectors or they arent opening.Try opening the airbox and shoot some ether into the intake.If it fires then you arent getting fuel.At that point you need to figure out if fuel is getting to the injectors.If you look into the airhorns with throttle wide open and kill switch depressed key on then have someone lift the kill switch the pump will cycle and you should see the injectors shoot a mist of fuel into the intake.Its tough to see and a flashlight helps.Be careful you follow the instructions to avoid it starting and running you over.Other way is with a noid light which plugs into the injector.
martin63092
cannondale27 said:Sounds like you are not getting fuel to the injectors or they arent opening.Try opening the airbox and shoot some ether into the intake.If it fires then you arent getting fuel.At that point you need to figure out if fuel is getting to the injectors.If you look into the airhorns with throttle wide open and kill switch depressed key on then have someone lift the kill switch the pump will cycle and you should see the injectors shoot a mist of fuel into the intake.Its tough to see and a flashlight helps.Be careful you follow the instructions to avoid it starting and running you over.Other way is with a noid light which plugs into the injector.
went in the garage today she started but she just kept on shuting off after 10 sec idling. still backfires tho
UpstateNY_sleds
Like cannon said, Check the injectorsand the coils. I would aslo check that there is not a kink in the long clear fuel line. It is looped near the front of tank.
If it runs and dies, it usually means running out of fuel. maybe new plugs as well. They may have gotten boogered trying to start it.
martin63092
tried her again started and didnt stop running, she didnt stall on me, i had to actuly close the sled. Still wondering what would caused her to do this yesterday.
UpstateNY_sleds
You said it was all snow. something must have been frozen....or you finally worked through bad gas or water. It idles down now? and stays running? cool. Glad to hear. I am just sitting here waiting for enough snow. Now today we get rain which is slowly melting whatever snow we had.
