SLED QUIT .. NO FUEL PUMP
apracing
new brunswick
Canada
2004 rx1 warrior 2006 apex gt 1979 enticer 340
Hey to all .. my sled quit .. code 42 .. fuel pump relay .. change it and away I went .. running along , quit again .. this time no start .. changed relay .. no pump ... check wires and ground blocks .. all good .. and I cant remove the code in the speedo .. check all fuses .. any ideas .. can I pin the relay to check the pump ? If so what wires .. any help would be appreciated
Sorry .. 2012 vector rs
Ok fuel pump is good .. checked all grounds .. like 8 or more ... harness looks good .. not sure.. ecm ?
I can by pass the fuel pump relay and it runs .. ground? Ideas ..still cant get the code 43 out .. hmmm
i think you are on the right track. sounds like you should look at all the ground blocks and repair as needed.
