apracing
- Feb 19, 2013
- new brunswick
- 2004 rx1 warrior 2006 apex gt 1979 enticer 340
Hey to all .. my sled quit .. code 42 .. fuel pump relay .. change it and away I went .. running along , quit again .. this time no start .. changed relay .. no pump ... check wires and ground blocks .. all good .. and I cant remove the code in the speedo .. check all fuses .. any ideas .. can I pin the relay to check the pump ? If so what wires .. any help would be appreciated
What sled?
apracing
- Feb 19, 2013
- new brunswick
Sorry .. 2012 vector rs
apracing
- Feb 19, 2013
- new brunswick
Ok fuel pump is good .. checked all grounds .. like 8 or more ... harness looks good .. not sure.. ecm ?
apracing
- Feb 19, 2013
- new brunswick
I can by pass the fuel pump relay and it runs .. ground? Ideas ..still cant get the code 43 out .. hmmm
i think you are on the right track. sounds like you should look at all the ground blocks and repair as needed.
