eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Was out on the lake last night with the girlfriend on the back and burned up my slides pretty good. My question is how do you get the melted plastic off the trailing edge of the clips? Will it hurt anything if you leave it on or should I try to scrape it off somehow? Thanks 8
berge75
Won't hurt nothing with plasic on the clips. You may want to update your wheels and mounts,because when you overheat those clips they will eventually loosen up and start falling off, and destroy your track.
grumpysanta
You can scape with a knife it is easy to remove but you have a lot of clips to do ... and it will hold heat and make the new slies wear out faster
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Ur saying it will hold the heat if I don't get the melted plastic off? I think I have a few beers worth of work ahead of me. Lol
zippo
- Dec 21, 2009
dont worry about ride in sum good snow and the plastic will come off on its own
yamahahaha
I'd cut the big chunks of plastic with a razor blade knife thing
It was mainly caused by the stupid, 3rd window closed track. I'm in the process of cutting out the windows in mine and installing clips.
grumpysanta
plastic on clips
use a hard knife short if poss. i have one that is only 1 inch long , takes afew seconds per clip . and only one beer . all open windows and all clipped is the best in my option
ingersoll113
yup
If the girlfriend is the #*$&@ in your avatar, send her my way and I'll burn mine up for her too lol..........
Easy Rider
Re: yup
Funny, I was thinking the same thing............
ingersoll113 said:If the girlfriend is the #*$&@ in your avatar, send her my way and I'll burn mine up for her too lol..........
- 6K
