shawnj
Will give that a go in the am. One hole left I think.Go all the way out with straps
I put snowtrackers on and their instructions were to let strap out but I wanted to test it some. I unloaded front ski springs per their instructions. I know i slightly skewed from original topic but might have some bearing.
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Make sure the sled is sitting on flat ground when you are looking at it
shawnj
Ya it’s on flat ground.Make sure the sled is sitting on flat ground when you are looking at it
shawnj
I found there were 2 holes left.Go all the way out with straps
I went out one. Which was about 1/2” from where it was. Hard to say if made much of a difference although doesn’t seem to be sagging quite as much. I will try this maybe today and then go the other hole out maybe.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Go all the way out.I found there were 2 holes left.
acpantera
- Sep 25, 2004
- W.N.Y.
- 22 TCAT+ATAC+EPS
If you let out the strap, make sure the spring is tight enough not to fall out of the retainer
shawnj
Okay. I looked and it seems fairly tight yet. I will double check.If you let out the strap, make sure the spring is tight enough not to fall out of the retainer
shawnj
I will my next attempt. Would I still need to when riding solo?Go all the way out.
I just figured out what the noise was I was hearing when hitting a mild bump. I have BRP tunnel mounted scratchers. The track was hitting the tip of the scratcher and I could not figure out what it was. It sounded like the track was ratcheting but the sound was from back left side mostly. I put scratchers down and we tested it out quickly and sound went away.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Here are some pictures of my skid. This is an SRX, setup stiff, firm preload, firm setting on IQS.
Yes, it is dirty..
Yes, it is dirty..
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
you might try one of those 4 position spring adjusters to get you through until you can get new springs. It will give you another setting higher. https://www.ndzperformance.com/NDZ-...-Adj-Blocks-4-Pos-Silver-p/acat-4-pos-sil.htm
acpantera
- Sep 25, 2004
- W.N.Y.
- 22 TCAT+ATAC+EPS
Grease the 4 zerk fittings in the rear skid, keep pumping till grease comes out some.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Make sure the fwd end on the rear spring holders are not upside down. Spring should be above the mounting bolt.
acpantera
- Sep 25, 2004
- W.N.Y.
- 22 TCAT+ATAC+EPS
shawnj, where you riding out of on your vacation?
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
I’m sure you probably know this but these sleds collapse the rear end for some reason if the skis are on wheels. Makes it seem like there is no rear suspension at all.
shawnj
I can do that!Grease the 4 zerk fittings in the rear skid, keep pumping till grease comes out some.
- 28K
