SLSA 1000' Speed run...first race of the season
justin1620
Rainy Lake, Ontario
Canada
Sidewinder
WEBSITE
www.rustymyers.com
Well its taken me a bit to get here but I finally cracked the 130mph in 1000' target I was aiming for. 131.38mph on pump gas, with a stock header, drivers, clutches, and track. I ran out of gear for what I was using that day, I'll most likely gear up for the next race and see what happens....Thanks to the guys that offered advice and opinions,...there is a lot of knowledgeable guys on here.
wow great speed in 1000' for pump gas boost levels! that's 140 in 1320 or close to it! What track you running?
Congrats Justin!! Attaining this speed with stock header/drivers is quite a feat, and the fastest I've ever seen given those parameters....kudos!!
What tune? Which muffler?
Max spool 20 with a 3” super quiet. Data log was showing steady 21-22psi…I’m going to throw on a side exit exhaust and taller gears to see if I can get a bit more for the next race
Keep us posted!!
