wildmann
- Dec 11, 2005
- Southern WI
- 16 viper rtx-dx
11 venture gt
09 vector ltx gt
05 vector
has anyone had a leak in their chaincase? I noticed a small amount of oil directly underneath that area on the garage floor, took off panels to investigate and could see a small drop on the bottom of the chaincase. the dipstick still shows it is full. I looked underneath and can't see where it is coming from, it appears as though there is a gasket that could possibly be leaking. Thanks, any input would be helpful.
xc_phazer137
Its one of 3 things. I have see this
1 First try to find a loose bolt around your chain case cover
2 If still keeps leaking repalce gasket
3 Have you tiped the sled over at all? Because oil can leak out of the Big tin can into your air box witch ends up on your shop floor.
couch
Had a chain case leak on one of the phazer mountains - it was a small cylindrical type seal on the inside face of the chaincase (not sure what passes through it) .. the leak would only appear after running the sled as there is a small area for oil to pool up in the area around the seal - fixed under warranty.
SharkAttak
any pic's of it?
- 27K
