Gone Blue
- Oct 11, 2006
- Howell, Michigan
So just need to pull the chain case cover off? I was gonna strip the it down(remove tank etc, already have tank and seat off LOL)
Also what grommet is to be used?
Yamaha 90480-11013-00 GROMMET This is on an 07 Venture Lite. Do I use the updated grommet or the old grommet. I plan to buy the new pipe
Yamaha 8GJ-17021-01-00 PIPE,OIL 1
Yes, you only need to take the chain case cover off. No need to tear the sled down. G.B.
Devin yamaha man
- Jun 8, 2014
- 2007 Phazer fx
136"
MBRP exhaust
Yamaha GYTR front shocks
I fixed mine on my 07 fx in the summer no leaks! and im running amsoil fully synthetic chaincase oil...my mechanic swears by that and amsoil fully snythetic oil in the 4 strokes!
2stroken
So a quick question has anyone found the pin out of alignment? I am waiting on my parts to come in as I have an 07 MTX(not leaking) and an 07 venture lite(currently leaking) that I am going to fix
Devin yamaha man
- Jun 8, 2014
- 2007 Phazer fx
136"
MBRP exhaust
I dont think its an actual a pin....when i tore down my chaincase on the 07fx it was just that grommet with the oil pipe inside of it.....the origonal grommet and oil pipe are not long enough causing the leak.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
I'm assuming you mean pipe not pin.
I think some of the 07's had alignment problems from day one. Mine got out of alignment after I had the side panel, off for welding and didn't realize it was an issue until it was all together. If you look in the hole you can See if it lines up or not.
Devin yamaha man
- Jun 8, 2014
- 2007 Phazer fx
136"
MBRP exhaust
after purchasing and installing the updated parts no more leaking...It was strange to find that the original pipe and grommet I had pulled out looked almost melted..
2stroken
Well I am thinking "roll pin" but yes
2stroken
So now the real question is who has these in stock? I ordered them the 1/1/2015, just got an email that they are backordered a few weeks, already have one sled pretty much tore down.
Would like to know price and availability if possible.
Thanks!
Thanks!
jonzeero
- Feb 23, 2015
- Other
- Phazer FX 2007
Hi!
Same problem here.
I ordered new oilpipe + 2 different grommets (one with original part number and one for newer models)
Did you use that longer grommet?
Same problem here.
2stroken
Used the longer grommet
jonzeero
- Feb 23, 2015
- Other
- Phazer FX 2007
Thanks! I ordered both trying to minimise the risk of wrong parts. Parts come from Netherlands to Finland
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I did mine even though I didn't have any issues in over 10 000km. Just makes me feel better.
Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
Same here, just didn't want a problem later on. I think the longer pipe helps keep the parts properly aligned.
Devin yamaha man
- Jun 8, 2014
- 2007 Phazer fx
136"
MBRP exhaust
Sometimes yamaha won't update the part numbers...but the parts will be updated
Yammer on the Rock
- Mar 16, 2008
- NL
- Venture Lite
