SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Well, Dusty Dan, what do you think of the aggressives on the Curve skis? Also. what is the difference between the two?Yes they do sell aggressive for Curves, I have been using them for 2 years.
Dusty Dan
- Jan 24, 2015
- 2016 SRViper LTX LE
2012 Vector
I like them and plan on continuing to use them. I never tried the non aggressives so I cannot speak to that.Well, Dusty Dan, what do you think of the aggressives on the Curve skis? Also. what is the difference between the two?
SideHogger
- Apr 16, 2016
- upstate ny
And you are using them on the curve skis?
Dusty Dan
- Jan 24, 2015
2012 Vector
Yes I am.And you are using them on the curve skis?
Mark Thompson
- Jan 21, 2020
- Feversham
- 2018 Sidewinder STX DX
Have any of yous had the slim Jim's first and tried the trackers I always had trackers on my vector and liked them. I'm curious to hear what the comparison is.
SideHogger
- Apr 16, 2016
- upstate ny
As soon as I wear out my semi, going to get the aggressives. Buddy tried slim Jim’s. Put trackers back on. Liked them better.
Mark Thompson
- Jan 21, 2020
- Feversham
Thanks I might order a set over the summer I think our area is just about done this yearAs soon as I wear out my semi, going to get the aggressives. Buddy tried slim Jim’s. Put trackers back on. Liked them better.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
get the trailer re
first trip to Sudbury , next trip to Timmins , and then Cochrane !
or northern Quebec !
I realized Sudbury is not that far away .
get the trailer ready , and chase the snow till April !Thanks I might order a set over the summer I think our area is just about done this year
Mark Thompson
- Jan 21, 2020
- Feversham
I parked my truck this winter to keep it pretty I figured may as well be ready for truck pulls this summer lol
get the trailer re
might only get one weekend here as the rain did a number on the trails here. did not ride sunday but i see quite a bit of brown from what i can see from the road.
Mark Thompson
- Jan 21, 2020
- Feversham
Ya we are the same condition here. I called parkway both his suppliers out of stock on trackers and royal dropped them by sounds of it so this mission is a next year mission now. But glad trackers work my sled is good with slim Jim's but I feel like there is room to improve lolmight only get one weekend here as the rain did a number on the trails here. did not ride sunday but i see quite a bit of brown from what i can see from the road.
mario750
- Jan 14, 2018
- New York
- LTX SE - sold.
I was going to put trackers on my Curves ski , but I could not get them on time, so I’ve installed another set of Jim’s for rest of this season. I’ll try them next winter if I still have a Winder.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
I have slim Jims on the curves for 2 years now, (winder 137) very tight front skid straight rate spring, very soft front end, and it's become almost playful, a little push, zero darting, but excellent in looser trail snow, wet or tore up, with no more inside ski lift. Hate the ski lift.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Have had a set of Curve XS skis on my 17 LTX-LE since almost new. Have been using Slim Jim duals on them, first the 6” set and found them to be too much for my 144 studs up the middle, and caused heavy steering. Now on my second set of 4” SJ with much lighter steering and 0 darting, and have gotten use to that light push in corners that duals give. Otherwise sled is so stable with my set up, that I really don’t want to try anything else. The one thing I am not enjoying about the SJ is rocks getting stuck in them when on very marginal conditions like this season has brought! It’s a pain to tip sled on it’s side and pound out the stuck rock or rocks. Have heard much talk about the SnoTrackers and am thinking of next season. For those of you who have gone down my same road, what is preferred for easy steering and that No Hands type handling feeling that I now have, Semi or aggressive? Any problems loading sleds on trailers with all that metal under ski, and do they also collect rocks when going over gravel?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I prefer Aggressive Snowtrackers myself. When they got worn finally after about 20,000 miles I elected to replace them. I dont think they had yet worn down to semi aggressive status however. The semis will push a bunk more in the corners is what I've heard from guys that have actually run both. That said, the Aggressive will also push if the snow conditions are loose and right around freezing or thawing.
Rocks will also get stuck in them the same as a Slim Jim dual. I would say it takes a larger rock however and less rock collecting on the trackers, you know when it happens as the snow will spray out and you can feel the drag.
If the trailer has a big step they will get caught, if no step its fine. I've used a 2x4 if you have a big step, some guys use a piece of PVC to help with loading. I've used trackers since they came out with them. Love them on the Doo skis myself, wont run them on a Cat ski like the old 2012 Procross had. I find them very unstable on the Cat ski, I believe they mount too far forward on the Cat ski which makes them unstable. I have had great luck with them on the old Yamaha ski and the Doo skis.
