yamaha06
Has anyone mounted ice scratchers on there curve skis? I have some trail blizzer ice scratchers I want to mount on my curves, just the only two spots that are flat to mount to are either at the front of the ski or at the back. I cant go to close to the center of the ski as they will be sitting at an angle then, not sure if that would matter. I have marked two pictures of curve skis, where would you mount them? I was thinking the back of the ski but no positive.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
I put in A position on inside of ski. Mine came with hooks when not in use and I mounted hook on ski bolt
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Here is the mount I made for this season
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
Yes similar to Kevin's mount Barn of Parts sells a breakaway bracket for mounting to the spindle bolts for $20. Works great.
yamaha06
Ya sorry, I should of made the arrow to the inside of the ski. Good idea with mounting to the front and using the ski bolt as a location to mount a hook. I was just worried that mounting them that far forward wasn’t sure how much down pressure they would be applying to the snow. I thought maybe at the back of the ski they would apply more pressure. Not sure though.
yamaha06
Do you have any pics of yours installed?
